Feature |
Product |
Release introduced |
Fabric Extend Integration with ExtremeCloud SD-WAN |
5320 Series |
Fabric Engine 8.10.1 Only 5320-48P-8XE and 5320-48T-8XE support more than one VRF with IP configuration. Beginning with Fabric Engine 9.0.3, you can specify the VRF that Auto-sense uses for SD-WAN on models that support a single active VRF. |
5420 Series |
Fabric Engine 8.10.1 |
5520 Series |
5720 Series |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.10.1 |
VSP 7400 Series |
VOSS 8.10.1 |
Auto-sense port Multi-area SPB support |
5320 Series |
Not Supported |
5420 Series |
Not Supported |
5520 Series |
Fabric Engine 9.0.3 |
5720 Series |
7520 Series |
7720 Series |
VSP 4900 Series |
Not Supported |
VSP 7400 Series |
VOSS 9.0.3 |
Note:
Requires a minimum of ExtremeCloud SD-WAN 24.4 |
5320 Series |
Fabric Engine 9.1 |
5420 Series |
Fabric Engine 9.1 |
5520 Series |
Fabric Engine 9.1 |
5720 Series |
Fabric Engine 9.1 |
7520 Series |
Fabric Engine 9.1 |
7720 Series |
Fabric Engine 9.1 |
VSP 4900 Series |
VOSS 9.1 |
VSP 7400 Series |
VOSS 9.1 |
If you have remote branch sites with only Internet connectivity and you want to extend the capabilities of fabric to that site, or if you have a branch office with a private WAN connection and you want to have a backup link using the public Internet, you can extend the Fabric network over the Internet towards a remote branch by connecting Fabric switches through ExtremeCloud SD-WAN.
Fabric Extend Integration with ExtremeCloud SD-WAN integrates the following features for SD-WAN deployments:
Automation of Fabric Extend Tunnels over IP WAN infrastructure
MTU configuration per IS-IS logical interface for Layer 3 interfaces
SD-WAN infrastructure adjusts packet size to accommodate restricted MTU paths, such as Internet, by fragmenting the end user IP packets.
This deployment provides the following benefits:
On 5320 Series models that support a single VRF, ensure you specify the VRF that Auto-sense uses for SD-WAN. For more information, see Specify the VRF for Auto-sense ExtremeCloud SD-WAN Configuration.
